Make sure that your pump is set to full speed ie 3.
These boilers do not like a 'slow flow' through them.
ensure the flow and returns aren't crossed.
I then took Tony's advice and tried turning down d0 still further, to 12 this time. Once again I was able to turn on the central heating system without the hot water system and everything worked. Wonderful.
Now I tried monitoring what would happen when the room temperature reached the level set by the room thermostat. The central heating went off as expected (S.30) which was all well and good, but then when the room temperature dropped and it should have started again then S.35 came up. This was displayed for 10 minutes and then the boiler got going again and stayed Ok.
I've tried turning d0 down even further to 10, but strangely the S.35 message comes up straight away then.
