When do you know if you need rewiring?
Hmm. Looks like old PVC cabling. It’s stranded.
Too much copper showing on the back of that socket, but the socket cabling itself may still be serviceable. Needs properly testing.
No earth in the lighting circuits, so those should be rewired.
Do let us know what your spark reports.
I agree.. I actually meant downlights :cool:
Don’t waste your money on an EICR. It’s rewire time I’m afraid to say.
Really?
I am a newbie to this, but is it really a waste of time getting an EICR?
So I should really ask my electrician who is coming out to undertake an EICR to price me up for a complete rewire instead?
Or do I just let him view the electrics and tell me what is required?
Do you usually pay for any of these services?
I know you did.
downlights
Why?
There comes a point when so much needs doing that there is no point in paying someone to tell you that a lot needs doing.
Given the age of the installation (old Imperial sized cables, unearthed lighting circuit) coupled with the inevitable bodges done to it since it was new it's unlikely that it won't need substantially replacing.
Then yiu have to factor in what you want in terms of circuits, lights, sockets, switches etc.
Yup.
You also need to tell him what you require in terms of circuits, lights, sockets, switches etc.
You shouldn't have to pay for quotes.
So I got a few electricians around and they all said that in order to accurately identify the remedial works necessary, they would need to undertake an EICR
So here's a here is a summary of the advice/recommendations given following the EICR
- All lights and switches have earth cabling. They have simply not been wired into the fittings.
- New ring main is recommended in the kitchen. As this area has the most power demand
- Insulation in cable is good (over 500) and should last 10yrs+
- Currently the living room and upstairs sockets are on a 32A breaker and the electrician recommended that this is downgraded to a 20A. Alternatively he could install a ring main
- Cabling above consumer unit is dangerous and needs remedial attention
- Cables above consumer unit have been extended and are without their protective sheath.
- Gas service is not earthed
Details of the installation covered by the report was 75%
Extent of sampling (inspection only) - 75%
So I plan to get to downgrade the sockets to 20A (living room and upstairs), install ring main in kitchen
Looks like i might be actually saving a bit of bob over a full rewire :)
What's your gripe with downlights? They're lovely :mrgreen::mrgreen:
Guys my electrician has quoted £9 to downrate the sockets from 32A to a 20A
Surely this is a mistake? or it usually this cheap?
Also, I wanted to ask whether in a 3 bed property would a 20A generally give me enough power or would it be wise to just get a ring main? (over 7000w)
It depends on what your 7000watts is comprised of.
3000 watts is approx 13A. You do the math.
IMO, 20A Isn’t going to he enough for a whole house.
Maybe install separate ring for kitchen/utility. That’s where the big loads will be.
£9 is probably the materials cost of the MCB (the new 20A switch). Could the labour be somewhere else, or just built into the job as a whole?
Apologies, as I wasn't very clear.
My electrician has given me a couple of options
Install 20A circuit for the 3 bedrooms upstairs which will provide 4600w of power
or option 2 would be install a new ring main upstairs (which would give me fresh wiring and over 7000W of power).
In both of the above options, I will be installing a new ring main in the kitchen.
I have just decided to go with a new ring main upstairs as the difference in price between the two options was negligible and it would give me peace of mind in terms of safety as I may rent the place at some stage..
Yes, I believe that you are right.. Labour was somewhere else.. Thanks for the comment!
