Where can I buy a double length double switch?
Well - apart from one module needing a bit of a clean, because I got paint in it (thinking it was to be replaced, I wasn't that careful when I had it off the wall to paint), they all work fine, so I might resurrect them with a new faceplate and knobs.
One of the controls of my double switch has failed
I can't find ANYWHERE where they have a double length double switch
Everywhere they have a double switch on a single switch
Where can I buy?
I've tried eBay, Amazon - then tried searching on google
Nothing!
Is my only choice to buy a gang of 3 or a gang of 4 switches?
See below for an image that I have:
EDIT: I've opened up and one of the switches has blown - there is no fuse that I can simply replace
OM
You need to observe the WATTAGE of the dimmer module. Since a large faceplate has been used, this suggests to me that a higher than standard dimmer has been used.
Write everything down that is printed on the dimmer module, and take a few photos if you can to show the wholesaler.
Don't disconnect till you have the new one. And make bloody sure you make a note where every wire goes before disconnecting anything, as you may have problems later.
