Why am I'm being put in mind of a grandpa Simpson soliloquy?
I can remember minis conking out in the wet -also metros....they did eventually put in a plastic cover to protect it.They were all using the A series engine, so all had the same problem but, the Minis were the worst.
The distributor wasn't on the front of the engine, it was at the side. But, because the engine was turned 90° the distributor was at the front of the car, right behind the grill.
It was the advent of OHC engines that put the distributor at the top of the engine and into the warm, dry area.I can remember minis conking out in the wet -also metros....they did eventually put in a plastic cover to protect it.
these days modern engines are full of plastic mouldings covering stuff up.
Super cheap anyway they could do it for the masses loads of which sold out of the UKIssigonis was so stubborn he was prepared to loose vehicle sales rather than fit wind up windows on the Minis.
You start off saying cars were reliable then go onto say you welded bodged patched them up.....not that great then....Fanyying on repairing cars might be your thing but it aint everyones.Maybe pre 1960 cars were more reliable ..probably only had a few moving parts and v few miles.LOL I've never read so much crap on any subject before, Leaves me wondering how I got into several in the morning, started it without any problem, went to work and same going back home also seeing hundreds do it going back home. This even before MOT's. Wanted to go some where say London from B'ham well go and then come back. Spend a couple of weeks holiday driving all over the place in Europe - no problem but spare fan belt, plugs and points and capacitor just in case. Never used them but did have a radiator leak coming back from London. Fixed with an egg. Friends had all sorts and no problems either. Maybe one difference to some people - able to service and replace parts that need it. I'm not a mechanic but it isn't exactly rocket science. In fact it was way way easier than it is these days. I know lots of people who have had sensor failures etc on "modern" cars. All makes.
Leyland did do something stupid as electronics went in even when there was very very little of it. They didn't use fibreglass circuit boards so soldered joints were iffy. Easily fixed in most cases by running a soldering iron over the joints but a totally stupid penny pinching thing to do.
When the MOT's arrived I found that I might buy a car with a valid one but it would fail on the next, usually rot. It was easy for some one to get an MOT to sell a car. Probably still is. No problem, get the stick welder out and fix it. Later as earning a bit more I mostly bought 3 year old cars. Exhaust would usually go during the first winter. Didn't take long to find what was need to find a replacement that wouldn't just get through 1 winter. The OE ones would usually last 3 years. A lot of the replacement junk that was around would only go through 1 winter. Usually fitted new plugs and leads and serviced it myself. Looked at brake pads etc and changed if needed.
One trick all along was to learn to be able to get an idea of what the real mileage of the car was and if it had been reasonably looked after. This still goes on. Take a Citreon Xantia. The makers put a tell tail in the ECU and found mileage readings on that were well over what was seen on the dash. Later gear was available to set mileage on all cars to what ever was required. I'd be amazed if it still isn't around. Service history really matters. I sold a Passat once with 98k on it. The dealer rolled back a bit and put a warrantee on it. The engine blew up on that not long after a timing belt change. I wont buy a Volkswagon again - substandard replacement parts. They were sold as genuine Volkswagon. They changed to a chain not long after the model I had so knew there was a problem.This one had a Audi engine in it as well. The mileage was higher than my usual as I used to go to a caravan in Pembrokeshire every weekend. I had shifted to buying pre registered cars then. Ok but to keep costs down to similar to running say 3 year olds they need to be kept longer and the money needed to buy them needs to be available. Some 3 year olds these days may be rather worn too. It varies depends on the mileage they have done.
As a kid we used to travel from the North to the South West for holidays, four adults and me in a Mini no opening windows in the back AFAIK and sliders in the front, roof rack piled high with luggage, Grandad puffing on his pipe, still great times thoughMinis lost sales due to the fact you couldn't wind down the front windows think baking hot countries...
Was not the wolsley hornet a mini with a bigger boot
