Hi all
Hope someone can advise me on this!
OK - I just bought an inflatable hot tub that's designed to plug into a standard 13A, RCD-protected socket... which saves me worrying about major wiring jobs - in theory! (It has a 15ft cable with an RCD plug attached.)
But I still need to figure out how & where to plug it in. There are no sockets in the garden, so I think I need to do one of three things:
1. Drill a hole in the outside wall of my house, feed the hot tub's power cable through it, and hope it reaches the nearest socket (which I don't think it will, quite.)
2. Assuming it DOESN'T reach, plug a suitable (capable of running a 3kw appliance) extension lead into the fixed socket & then plug the hot tub (which has an RCD plug on it) into that.
3. Get power outside somehow - am I right that you can buy kits that are basically a plug one end and an outdoor socket the other (i.e. an extension cable that permanently leads from an existing indoor socket to a new outdoor socket)? - again by drilling through the wall, and plug the hot tub in outside. I'm worried that might be made awkward by the fact that the hot tub plug is a non-standard shape (being an RCD unit) and so won't fit a standard weather proof socket, and also by the requirement to site the socket well away from the hot tub - could mean some long cables trailing around!
Simplest option to me looks like 1, with 2 as a backup if the hot tub's own cable won't reach the socket. It would also mean all plugs & sockets were inside in the dry, which sounds safest to me. But I want to be sure it'd be OK to use an extension cable permanently like this, and that there's no compelling reason to use an outdoor power supply.
Many thanks in advance for any advice.
