Hi there,
I'm considering installing a water accumulator/expansion vessel. Looking at TWS, GAH or Altecnic installation instructions most are showing accumulator connected at the "beginning" just after the single check and pressure reducing valves. Some instructions are showing connection before and some after the kitchen tap. More importantly some are saying the accumulator can be connected anywhere and the further from mains the better. So, different instructions seem to be giving slightly different recommendations.
My cunning plan is to connect the accumulator at the "end" in the loft with 22mm pipe allowing it to supply the boiler and cold water to the bathroom (but not the kitchen tap).
Can you guys advise if this is OK or if I need to connect the accumulator at the beginning (close to mains)?
