Thanks for that, the Worcester is £410 dearer because a five core cable needs to be run upstairs to the airing cupboard.Baxi 816 good little boiler with ten year warranty and baxi rarely quibble or try and get out of repairs . worcesters marketing is better than their boilers but still not a bad little boiler . come down to price and warranty length
It's a fair size 4 bed detached house. The trouble is where the boiler is fitted it needs a rear exiting flue, do you know of any others that would be good to have?Of the two I'd take the Worcester, although in reality I wouldn't particularly want either of them. Baxi has terrible modulation of only 2:1 and is horribly expensive to repair once the warranty runs out. Plastic casing goes yellow over time.
15Ri has better modulation but is very dirt-sensitive, a pain to service, and only accepts on/off controls.
Does he actually need a 15kW boiler? Has a proper heat loss calculation been carried out?
I've asked my son and he was told 15Ri would still fit in the space, I'll ask him to investigate the Vaillant options, thanks for your help.Well that knocks the 15Ri out then as there's no rear flue option for that, it comes off the top. Vaillant ecoTEC Plus 412 or 415 can accept a rear flue and are decent boilers
They've said they need a rear flue, which isn't available from Viessmann or IntergasIm also looking for a heatonly - Why go for baxi? My choices were all of them and I shortlisted a viessman 100 or a intergas OV so what is the reason you are choosing something else
good luck getting parts easily for the viesmann when it goes wrongIm also looking for a heatonly - Why go for baxi? My choices were all of them and I shortlisted a viessman 100 or a intergas OV so what is the reason you are choosing something else
Would Intergas be much better / quicker? I realise the two I picked are more quirky and less populargood luck getting parts easily for the viesmann when it goes wrong
Baxi certainly do not have bad response times if it was to need a warranty call they would be out same or next day if i called them and once out of warranty parts are available in majority of merchants off the shelf or next day Vaillant much the same in response times .Would Intergas be much better / quicker? I realise the two I picked are more quirky and less popular
However the Baxi and valiant boilers have equally bad response / reliability times
Why look for an alternative to heat-only? It's almost certainly the best option, especially as it's a replacement of an existing boiler.there is an alternative to heat only which is 21st Century tech....Its amazing what can be saved in terms of capital cost and running costs. https://www.energymanagermagazine.co.uk/rinnai-and-the-art-of-zen-and-zen-plus/
