High there
I have moved in to a 3 bed house. Standard Wimpy crap from the mid 90's. Hollow dry walls, and an old fashioned system.
* 8 Radiators
* Two Tanks ( I think) pitch on the roof is so low I dont go up very often.
* Cylinder in cupboard
* Potterton Prima F (conventional) biler chugging away quite happily in the kitchen.
Now I would have been happy with this set up, as it works. However after installing a new bathroom, and those new fangled barrel taps (quarter turn jobs) I now have a useless shower. It wasnt great before hand to be honest 'bearable' would be the word.
So I decided to put in a pump. The only issue is, I dont want the noise, I dont want the yards of plumbing needed and the possible reliability issues once installed.
I was also getting confused about why I could have it under the bath and why it had to be in the airing cupboard. Basically it wasnt going to be as easy and cheap as I thought.
The next option came to Pressurised tank such as the Megaflo.
This seemed like a great idea becuase I would have no need for the loft tanks (although they dont get in the way and cause any problems), and I would have mains pressure to all taps allowing me to have a decent shower again. (My shower runs off a mixer from the taps)
Then I started to learn about the on going costs (annual inspections) and how much it would be to install. It will probably cost about £500 more than a pump. This has started to become annoying becuase i will essentially be paying yearly for pressure in taps I dont need really. I only need better pressure in the shower.
So I am stuck between the two choices. I havent as yet found out how much it is exactly to fit the Cylinder nor the ongoing service costs.
Then I started thinking. If I get a Combi boiler. That way I can get the mains pressure to my shower without the need for a pump, a more economical boiler/heating system and get rid of the tanks and the cylinder.
Then there are the downsides. Combi boilers are notoriously fussy and unreliable. If they break down, you will have no hot water. They might not be able to supply enough hot water for the shower pending on the pressure. I might not have enough pressure to run a combi (obviously I will have to find that out)
There is also the other choice of getting a system boiler, which I assume works with the Pressurised cylinder (megaflo) or it works like my Potterton. Im not 100% sure what they do although they sound like a good alternative.
Basically im learning al lot and a decision like this should be taken with a better understanding of the choices, hence why I am here asking fo some advice.
I want to get the right system/solution becuase its going to be the one that lasts another 15 years at some expense.
Im leaning towards maybe A combi with stored water. That way I can get the economical product with some hot water back up. I am still concerned about the lack of available hot water to more than one outlet (tap). I would also want one that is bullet proof and doesnt constantly break down (like the one I had whilst I was a student)
So maybe the system boiler is better.
?????? Please help. Dont forget this all started because of a bloody shower lol.
* 8 Radiators
