Which driver?
30 Mar 2015
Hi All,
I saw a builder using one of these today and the speed at which it was inserting screws as well as the depth it could go into a wooden batten was putting my Makita drill/driver to shame.
Can someone confirm which model this is and whether there is an equivalent or an alternative that they would recommend with this range?
I will be using this to screw plasterboards to the ceiling and build stud walls.
all impacts are similar in the way they work regardless off make so just get one to match your batteries
In the case of 18 volt Li-ion Makita the equivalent would possibly be either the DTD146 or the DTD129 which are both single speed models. For a 3-speed model (more expensive) you'd need to look at the DTD148. Yes, impact drivers run rings around combination and drill drivers for 1st fix work, but be careful what you use they on - they can snap smaller gauge screws like carrots and they can be a bit dodgy to use on hardwoods unless you take a deal of extra care
In response - yes Makitas are as powerful as Milwaukee, and they are probably a bit more reliable - out of two plumbers and one chippy on our site who use Milwaukee all have had at least one warranty return done. Can't say I know of anyone with a Makita who's had that issue. My BTD145 is pushing 5 years old (site use) and tatty looking but still works perfectly well
Two of my colleagues (carpenters) plus our apprentice each have one each. Good balance, good battery life, powerful and the all metal nose will take a bit of a beating (probably a better nose than the plastic shielded nose on mine). I've tried them and they do the business.
One point - they do need 3Ah batteries or above
