I take it the cutters mentioned come with a blade to start with,but how many tiles would a blade cut before needing replacement?
I realise this smacks of how long is a piece of string,but just an average will do(floor tiles)
twice as long from the middle to the end (the bit of string that is)
noramlly they do and they will normally last quite some time as they are usually diamond blades (more than long enough to do a kitchen and a bathroom, unless theyre relly big!)
get yourself down to wickes, £50 quid sells you their wet cutter. I've been tiling for yonks and its better then any cutter out there. I once had a top rubi wet cutter, waste of dosh...............
