Which GU10 dimmable LEDs? (BG switches and rotating dimmers)
1 Jul 2004
London (North)
Hi
I'll be replacing some LEDs that have died after two years.
The current brand are Luceco
Light switches are BG (British General) electric. These include rotating dimmers. And also a few with a Shelly also wired in.
Thank you
Once upon a time I'd have said Megaman Dim to warm, but I'm kinda annoyed that out of the 100 I bought 8 years ago, around half of them have failed (used with Fibaro dimmers). At £7 a pop I was hopeful for better longevity
The Philips WarmGlow have been slightly better; only about an eighth of those I bought to replace the megamans have gone wonky, but I definitely prefer the light from the megamans..
Sigh
We used Megamans at the last place (that was 2015) and they were the only LED GU10s that I found to successfully dim. Things have moved on since then.
Phillips seems to get good reviews. Thank you.
But I'm out of the loop with these so keen to hear from others who deal with 100s of them as well as you.
Hah, no problem. Don't forget though; those who deal with 100s of them probably do it professionally (and are long gone by the time they're all failing) rather than live with them
If you want a light which has some ambiance, so the colour temperature changes, I would say little option but use smart bulbs, I have looked at controllers, and the TP-Link or (Tapo) do a press button turn switch
that does seem to link to their bulbs giving good control, well in excess to what one could expect from a hard wired set up. I have tried the switch, but not the bulb, I found we simply did not use the switch, voice commands worked better, so it became my door bell push.
But there are so many options, may as well be blind folded and stick in a pin. However hard wired options seem to be on their way out.
