- Joined
- 24 Oct 2018
- Messages
- 144
- Reaction score
- 0
- Country
Hi all,
so, I've now finished the walls in my garage - used 50mm polystyrene for this.
But - now I want to do the ceiling (I know, bad order to do this in however I needed the ceiling exposed for cables and the walls completed for sockets)
Now, I'm only going to insulate between the rafters - not between and on top, mainly because there are places already complete and I want it all to be level.
So, I understand celetex to be a superior insulator but will I actually notice the difference as of course the cost difference is quite large.
I will be using 75mm insulation and have the option of polystyrene (£26 a sheet from Local store) or Celextex at £55 a sheet, now of course I can use thinner Celetex and get the same thermal efficiency as the 75mm poly but may as well use the thickest I can.
Just wondered if in reality I'd notice the difference.
I will only be using a single 2kW heater, this is installed into a thermostat plug which is controlled via an app, so I will be maintaining the room at around 13 degrees all the time, then at "peak times" (i.e. when i'm home) i'll push it to 16/17 and then bump it up if I intend to be in there for a longer period - if i'm working on something for example.
So, I need the 2kW to be sufficient - no point using 2kW of heat when 3kW is escaping!
some calculators say 1600W would be ok, some say 2.5kW (18m2 room) so I'm hoping what I have will suffice.
So, should I opt for Celotex or will I be ok with the polystyrene?
