Going around in circles here, so hoping for some advice on the best value low end kitchen units for my small budget.
Wickes flat pack is looking best so far, but there are so many on line companies offering units and I wonder if I would be better off with one of those.
Perhaps if you have used some of the on line companies you can comment on the service and quality of the units.
This layout gives an Idea of what I was hoping to do.
View media item 15687
Its 2800 x 3650mm at present bare room with a 1800mm window on the short side, open plan to the dining area to the left of this drawing and open to the existing kitchen at the lower end of the drawing. The only stipulations are sink and a half under the window with dishwasher under the left drainer & a tall double oven housing on the right hand end of the run of units.
A 60cm gas hob which it seemed best suited to being central on that wall with either 60-80 or 90cm hood over.
I read that you shouldnt have wall units close to the hob so set them back some and used a 90cm hood in the drawing, but I'm not sure if that will look out of scale.
I'm looking to spend around £1500 for the units, other stuff like worktops and appliances I can find later.
