Got a bit more done on this project.
The 900mm hood has a 150mm extract outlet and my biggest core drill is 127mm, so not wishing to buy a new core drill for 1 hole I elected to suffer a bit of arm ache by cutting the inner hole with a pad saw
Its plaster and soft block so not too hard to do, just took a while to get round the circle. Doing it that way also meant I could have the vac hose up against the hole to stop the dust going everywhere.
The outer hole was done with my core drill then stitch drilled to size.
Turned out really good size wise with only 5mm clearance around the tube to seal when finished.
I have in the past had trouble using the 127mm core drill on hard brick as the pilot drill bit chews the hole out before the core has cut far enough to keep centered. This time I cut a small block of timber, drilled a pilot size hole in it and screwed this to the brickwork over the existing pilot hole, this meant the core drill couldn't wander while getting a good bite into the brick. Shall use this trick in future as it worked well.
View media item 18875
Fitted the dishwasher and the cover door for it, thats the 2nd unit from the left. The sink door and dummy drawer (3rd from left) I drilled and inserted stainless 8mm pins to hold the 2 together pretty much as they had done with the dishwasher door/drawer.
View media item 18876
The plinth is just offered up for checking atm, but I think I will need to space it away from its normal position some as the floor tile line differs from the wall so the grout line will make it look odd otherwise.
Cant make up my mind re the left end filler panel, not sure if to cut it back at the bottom to continue the plinth line or leave it as is?
I do have to cut the plinth lower to clear the dishwasher door when opened & I am thinking at buying some clear plinth to floor sealing strips. The bottom of the plinth does have a white plastic strip stuck on it but I guess any spillage may get past that easily?
The worktop in the pics is just some old spare bits, the finished one will be gloss black granite laminate.
We removed a radiator when knocking through to the new extension and just got around to refitting a rad, the original was long and low under the window. Only had a small 600mm wide space so this was the best solution without going to the expense of a designer rad. 500mm wide and 900mm tall double.
View media item 18877
I have a filler to make up for the corner where I altered the cabinet spacing to allow for drawers on both sides and the tall unit has to be removed, the outer end panels cut to size and I have some handles yet to fit, but its getting more like a Kitchen now.
View media item 18878
With the tall cabinet out of the way I can be more flexible when mitering the worktops, cut the female on the window wall, fit in place then cut the male on a full length and if its not correct go again knowing I have plenty spare. Once its right I can cut for length then refit the tall unit.
The electrics are now all finished, electric double oven waiting to go in, gas pipework installed & gassafe plumber lined up to connect both ends once the worktops in place for £75.
I still have the pelmet and cornice to cut and fit, I have a sliding mitre saw so I am hoping that wont turn into a drama, I need to order some mitre glue for that job.
The hot and cold supplies are run through to the sink base unit but until I have the sink fitted I cant cut through the wall for the waste as i'm not quite sure where all the wastes will end up from a bowl and a half, so not quite finished making a mess yet.
Any tips or hints on any of the above taken willingly
