Which Shower
2 Jan 2007
Hertfordshire
Hi chaps
want to replace my electric shower (mains fed only) to a non electric shower that uses the hot and cold water supply, want to put over a bath can anyone tell me my options please....i live in a bungalow and the hot water pressure is not great....
Thank you
You'd maybe like to consider an electric 'power shower'......they take low pressure hot and cold water and boost the pressure internally, and they look just like a standard electric shower.
Screwfix 68019.
John :)
hi
thanks for response, i wanted to get away from the electric shower look realy...was thinking of a mixer shower but not sure if that would cope with low pressure hot water?
You need to measure from the top of the shower head to the bottom of the header tank....1 metre = 0.1 bar pressure which is the absolute minimum for gravity showers. If you have 2 metres height, then there's much more choice but do check the manufacturers specifications.
John :)
