B
Big_Spark
Beanzy, at the supply end you fit a 500mA 40A Type C time delayed RCD, this will protect the cable, and the installation involved.
At the garage end, the power to the Amps I would supply via a Type C MCB if the inrush currents are high, however in my experience this is not the case, so would settle for a Type B.
It would be wise to seperate the circuits though and have two or three 16 or 20A rated circuits.
I think people often forget that the Garage MUST be RCD protected, but that electronic equipment often results in nuisance tripping, hence the high fault current and time delay.
