It really isn't complicated at all.still none the wiser which cable to use - that tool is complicated - could anyone help
If you want to design and install the electrical circuit for the gates then you have to do it, not somebody here.
You have to take responsibility for doing it properly, not somebody here. You have to know what you are doing and you will have to sign the declaration on the EIC which reads:
FOR DESIGN, CONSTRUCTION, INSPECTION & TESTING
I being the person responsible for the design, construction, inspection & testing of the electrical installation (as indicated by my signature below), particulars of which are described above, having exercised reasonable skill and care when carrying out the design, construction, inspection & testing hereby CERTIFY that the said work for which I have been responsible is to the best of my knowledge and belief in accordance with BS 7671:2008, amended to 2011 except for the departures, if any, detailed as follows:
Or you have to get an electrician to take responsibility for it.
