Which Tile Adhesive should I use?
21 Jan 2016
Hi
I have tiled two walls before in a bathroom so just a normal DIYer (I was pleased with my end result). My tiles were 100 x 100 and I used powdered adhesive. I found it time consuming to keep mixing up. I think I had to mix up frequently because the adhesive went off really quick.
It looks like I will be tiling another two walls - the tiles measure 300 x 200 white ceramic and will be above a bath which has an over head shower off of a cylinder tank emersion heater.
One of the walls still has tiles on, they are rock solid and I am up against it time wise - I will be tiling straight over the top.
I have read good reviews on Bostick Non Slip Tile Adhesive - would this product be OK to work with? Just worried if I am a bit too slow and the product dries out.
https://www.wickes.co.uk/Bostik-Non...15L/p/167965?_br_psugg_q=bostik+tile+adhesive
The description seems to imply that it would be OK if it's "correctly grouted"
But I wouldn't do it.
Standard set powdered adhesive has a pot life of around 4 hours, surely that's long enough? You don't need to mix the whole bag in one go!
