I've been told this CU is an old council one with only 2 neutral busbars so it would be difficult to add a 2nd RCD.
So could I simply replace the MCB's on the unprotected side with RCBO's?
I've seen talk here about different types of CU which need different models of MCB, so which type of RCBO would I need for this CU (see photo below) ?
Finally, can I legally replace the MCB with an RCBO or must I get a registered electrician to do it?
I've looked up the LN5915 MCB and it says M6 Type 2, and searching for RCBO's which are M6 Type 2, I can only find 2nd-hand LN6330 32A ones. I guess I could move the ring mains to the unprotected side using LN6330's and put the lights on the protected side. Would that work? But I'm guessing that would not be a replacement so would definitely need a registered electrician?
