Which vibrating plate for 150mm of MOT1?
13 Aug 2006
London
Hello, before I go ahead and order, can anyone shed some light on which size vibrating plate I should rent from HSS?
http://www.hss.com/index.php?g=47428
I need to compact about 150mm of MOT1. Would the 'Hauc Light Vibrating Plate' or 'Hauc Medium Vibrating Plate' be the best candidate for the job?
Thank you
d.
For the little difference in price id go for the bigger. Worst it'll do is squash your MOT down a bit more!
Only downside may be it might be less manoeuvrable than its smaller cousin if you have a lot of corners or tight spots to get into.
