Which Wago connector?
18 Jan 2006
Cumbria
Which type of Wago connector is suitable for 2.5mm2 stranded cable. The Wago site seems to suggest that the push type connectors are not suitable but the lever type are. However, other sites say the push connectors can be used with stranded cable. Any advice welcome.
I always use the lever type for stranded cable.
I note the Wago site says push connector suitable for stranded, but I’ve had problems with finer stranded.
Thanks. I must have misread the Wago site info. I have some of the push type but I think I'll order up some lever type connectors to save any problems when it comes to doing the job.
The datasheet for wago 773 connectors only talks about "solid" and "stranded", while the one for wago 222 lever connectors talks about "solid", "stranded" and "fine stranded"
I presume "stranded" refers to stuff like conduit singles, while "fine stranded" refers to stuff like flex.
