- Joined
- 17 Sep 2012
- Messages
- 12
- Reaction score
- 0
- Country
I need to hang a guitar holder to the brick wall. The thing is, although sold in Europe, the hanger is US made and comes with an imperial size screw, 1/4 inch (6.35mm). Measured length is around 42mm or so. The
Which wall plugs should I use?
Been looking at Fischer S nylon plugs, but should I use 8x40 or 10x50? 10mm is spec'ed for 6-8mm screws, so within range, but it's a but on the lower end of it and the screw won't reach the end of the plug. Should I go for 8x40, although it is spec'ed for up to 6mm screw?
P.S. I should mention that the screw is a special double ended type (more like a dowel), threaded on one half and wood screw on the other, so changing to a different one is not an option.
Thanks,
Kostic
Thanks,
Kostic
