Hope someone can help with a problem that is driving me crazy.
I recently (6 weeks ago) had a new Remeha Avanta Exclusive 39c condensing boiler fitted, replacing a (very old) boiler that was part of a tank in the loft, hot water cylinder in bedroom cupboard type setup.
The problem is a high pitched whistling noise that can be heard from the boiler and also from all of the radiators throughout the house. It is extremely loud, annoying and wakes me up when the heating comes on in the morning. The installer has simply referred me to the manufacturer and I have had Remeha (Baxi?) engineers out twice to look at it. They tell me they have replaced various parts in the boiler including diverter valve and “all the hydraulics”?, but the problem has not been fixed.
Characteristics of the problem are:
When the system first fires up from cold it usually takes about 5 minutes before the whistling starts and then continues for as long as the heating is on.
If a hot tap is opened, the whistling stops and then starts again as soon as the tap is turned off.
I tried opening and closing all radiator valves (I have thermostats on all but 1 in the hall) and noticed that if I turn all radiators off except the one in the hall the whistling stops. Turning the radiators back on one by one, the whistling starts again once I turn on the 5th or 6th radiator (there are 12 in total). I have tried this a few times and it doesn’t matter which order I turn on the radiators, it is always once there are 5 or 6 ‘open’ that the whistling comes back.
Any ideas?
Any ideas?
