Surges and spikes in the USA mains supply are far more common and often have far more disruptive energy than here in the UK. The reason is the short cable distance between supply transformer (11Kv to 110 + 110) in the USA and the subsequent lack of significant stray cable capacitance and reactance between transformer and domestic socket. This capacitance and reactance is much greater in the UK and provides a filter for spikes generated at the transformer when the loading changes.
In the USA there are many places a few houses share one "tin can" transformer on a pole in the street. If one of those houses reduces its load on the transformer by turning off an appliance then the transformer reacts by creating a single cycle transient over voltage spike which easily reaches the other houses.
A 2Kw reduction of the total load of three houses has a far greater affect on a small transformer than the same reduction of the load of 30 houses on a larger transformer.
Hence the need to protect against surges and spikes is far higher in the USA where "tin can" transformers are very very common
