Sprogginz
So you have removed the socket and now you should have six wires sticking out of the wall.
You need to re-connected them so that the ring is again complete. It is important that you do this, even if the removal of the socket is temporary.
You need three bits of insulated terminal block. Connect the red to the red, the black to the black and the green/yellow to the green/yellow./
Or brown/blue, gn/yell if you have newer wiring.
The terminal block should be capable of carrying a current of not less than 20 amps.
Yes you have, and that is not right.Is it because I've unintentionally turned a ring circuit into (if possible) 2 radial circuits?
