ChrisR said:As I said masona - you don't mitre internal corners because wood moves - crucially in this application it shrinks. That reason IS NOT given anywhere above where I first mentioned it. Ok? Learn to read mate?
I learned that at about 14 years old - yet 10 posts here and nobody mentions it.
34 years of doing it wrong and not knowing why - should be ashamed of yourself!
In future on the forum I suggest you read the question more carefully.
Bits sniped.....
Did you honestly think I use pins on front of the internal mitre ? Have you not heard of secret nailing ?Pinning an internal corner to stop it shrinking? Is that meant to be funny? It's pathetic.
I can pass a lot of secret tips, for example how do you cut a square or 45 degree angle without using a square, just you and the handsaw ? Even carpenter working along side of me don't know how I can do it ! Am'I shame of myself ? No, I very proud of myself condisering the disability I was born with.34 years of doing it wrong and not knowing why - should be ashamed of yourself!
It can be done if you know how to but can only do so for 45 & 90 degree angle only, it is so easy to do.. But I do use a square on quality finish.All sorts call themselves carpenters, but if someone can't cut 30, 45, 60 and 90 with just a saw and a pencil, he's not one in my book.
Sorry, I don't see anywhere where I've has a go at you, if you have read it that way then it wasn't intended, then apologies but I will never insults people just as you did but then that is you. Your last post was much better.ChrisR said:If anyone doesn't read what I have written properly and has a go at me on that basis I'll jump on him
Who said that ???????Using nails in an attempt to stop shrinkage
masona said:Anyway don't worry about replying,
I've given a lot of thought and decided to call it a day, may come back one day, I don't know.
I hope I've helped some people here.
Cheerio
That was probably masonaAdamW said:In the living room they had been mitred, both internal and external corners. Although I must say the mitre is very good, must have been done by a competent joiner
