So, the situation is that the CH header tank keeps filling.
There is no problem with the ball valve and also the coil in the hot water cylinder hasn't gone.
When the tank does fill, it comes from the cold feed off the bottom of the tank, not the main.
You can actually feel the water rise from inside the tank. This all happens when the boiler is running (ie pump running).
The pump is on the right way round, the cold feed and vent are in the correct position, the system has worked for years, no problem. Now this happens.
Any ideas???????
Any ideas???????
