- Joined
- 13 Jul 2007
- Messages
- 118
- Reaction score
- 0
- Country
Sorry guys, on my first post, I meant the stat on the cylinder.
Noise is definately the pump - no question. You can hear the drone throuout the house, and as soon as you open the airing cupboard door, it's right in your face.
Not sure what a fully pumped system looks like, but the pump feeds a two way honeywell valve. One 22mm output feeds the rads, the other 22mm feeds the input of the heating coil in the middle of the cylinder. Interestingly (?) the output at the bottom of the cylinder is only 15mm and returns directly to the boiler in the kitchen.
Pump isn't knackered as it runs silently when the tank stat is turned down.
The noise is a combination between a droan and as if air is trapped in it although it is vertically mounted...
Can't imagine there is too muh junk in the system as it has been drained a few times in the last 12 months to service rads etc.
