Why does washing machine have to be double poled?
Screwed said:
Cheers, will go for option A, already got the switch with neon light, will have it plugged in, in the cupboard tonight! Why make plugging in a washing machine so awkward!!!!!
Hmmm...safety? I heard somewhere that washing machines were a major cause of domestic fires...maybe not, but best keep it isolated when not in use, though they probably catch fire when they're in use, if at all...
I remember reading on the IEE forums about problems with washing machines and high earth loop impedances creating a fire hazard. I've had a look but couldn't find the thread.
High EFL's require RCD protection anyway, so fire protection should be covered.
I know not all High EFL installs necessarily have RCD back-up....
Sorry...pointless post!!
What's the diffrerence between the fuse being in the plug or the fuse being in the switch?
PS: Started to read that thread but it flew over me!! One point though, why can you run a lawn mower off of an extn lead but not a dryer? (or can't you!!)
No difference, but if it's in the switch it's easier to replace. Also, if it's in the switch (as in FCU), you could downgrade the cable from the switch to the appliance if necessary (keeping to the requirements of the regs, of course!).
The difference is that any equipment that is used outside, must! be protected by RCD, unfortunately not all ring circuits have to. When I install a new ring circuit or modify an existing one I try to convince the occupier to install RCD/RCBO in all of them (Ring circuits), and normally they will accept this option.
