Hello
I am wanting to install a ventilator in my loft and so was planning to bring a spur with a 3 plug socket from the first floor ring main up into the loft.
But the manufactures instructions say it should be wired into a fused spur and there is an FCU supplied.
But ive read fitting an FCU needs to be done by an electrician. Why if wiring a socket on a spur doesn't?
Also on a side note. Why can you not simply put a plug on the end of a 3amp FCU and plug it into a wall socket instead of wiring it into the ring main. Surely thats no different to a spur?
Cheers
Al
Cheers
Al
