- Joined
- 27 Jan 2008
- Messages
- 25,004
- Reaction score
- 2,894
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I know it will not work with RCBO's and it would use two slots instead of one. But a few have talked about radials instead of rings because with a ring high load either end can cause an overload without tripping the 32A MCB.
Fit instead two 16A MCB's and most of the objections to rings vanish. Should the ring be loaded heavy one side or even broken in error the MCB would still ensure automatic disconnection with an overload, yet still give one most of the advantage of a ring final.
As to if the two 16A MCB's should be linked not sure? Also not sure if two 20A MCB's could be used to give a 40A ring final?
So why don't we do it? I must be missing something but what?
