OK - apparently you can have as many double gang sockets as you like on a 20A radial over 50m² but the more you have, the more likely the MCB is to trip.Don't be ridiculous.Unfortunately, that leaves you with a single double gang socket on each 20A circuit
As a kid I lived in a house with rubber insulated radials and blown fuses were a regular occurrence, especially when my sister was drying her hair with a hair dryer sitting in front of a fan heater and someone put the kettle on - her favoured socket in her bedroom was on the kitchen radial. After we had the ring finals, we never had a blown fuse again. Maybe the fuse protection was inadequate and we were living in a fools' paradise/death trap. However, the Pyrotenax cable wasn't going to melt.Don't be ridiculous.The ring main may not be perfect, but it is far more convenient to a bozo than multiple radials.
When my sister moved to Sweden, it seemed like going back 10 years when she had to learn what she could plug in where not to blow fuses.
This has left me with the impression that a 30A semi-enclosed fuse 'protecting' a ring final is unlikely to blow, regardless of where you plug in your fan heaters etc. (A 30A MCB will trip more often than a 30A semi-enclosed fuse would blow.)
A small house with a single living room, like the one I'm refurbishing to rent. A single fan heater won't heat the living room in cold weather. Fan heaters are generally supplied under a central heating service contract pending repairs.What - all at once? What kind of house has all those going on in the same room?A couple of fan heaters, a hair dryer, iron and plasma TV at least.
The idea that two poles protect the live (line) conductors and the other two poles protect the neutral conductors, all linked to isolate the whole circuit so a fault occurs if ANY conductor carries over 20A. The RCD component protects the whole ring final rather than individual legs. The total ring capacity would be 40A (close to the old 30A semi-enclosed fuse blowing current). However, the ring final is protected from local heavy loads near the CU.What's hypothetical about it?With my hypothetical quad-pole RCBO
http://www.gepowercontrols.com/10086/pdf/residential.pdf
http://uk.farnell.com/merlin-gerin/c60hb420/mcb-20a-4pole-type-b/dp/1421093[/QUOTE]
Thanks, but not what I had in mind.
