Some plasterers skim plasterboard with 3-4 mm of plaster. But why is this necessary? is it not defeating the purpose of using platerboard to avoid the messy plastering job? I thought the filler used in tapered joints was enough to give a nice and smooth finish
skimming a wall will not make a blind bit of difference to the sound qualities im afraidOne possible consideration that might make skimming worthwhile is that Oz houses are quite resonant. You can hear through the walls about as easily as if there were only a flyscreen between you and the other person.
also, I would guess, because it takes less time (for a professional) to skim joints than a whole wall, and, of course, far less cost in labour/materials.
t
if its done right and each satge is done right its a far better finish then plastering.
t
Depends on the tradesmen involved !
You say that jointing is a better finish and less messy than your plastering?
No further questions , Your Honour.
So taping is less messy, so when a plastered the lids in a house recently, lifted the dust sheets from the floor and walked out, job done. if the same job had been done t&j then after sanding down The client would have had to spend days dustinging and hoovering. Thats why I prefer skimming. also I find it quiker, and more and more of my french clients are now wanting skimming rather than T&J
