Why would i replace Hot water cylinder ?
22 Oct 2008
Birmingham
I have just had a quote of £2175 to replace my warm air unit with a J&S Hispec J25 with water heater included and sort out vent problems (FLUE)and replace grilles & registers.
At the moment i dont have the water heating , i have an electric emmersion heater.
I am quite happy with this quote but they are asking if I want to replace the hot water tank with a 36x18 direct cylinder for an extra £350
They say they can do the job without this , so why would i pay the extra £350.
Thanks.
Luke
If your intention is to get HW added later to the unit then it would be better to fit an INDIRECT cylinder with the flow and return connections capped(just to be safe),
Only reason to change it at present for same is if its showing signs of leakage its not going to save you a vast amount of energy with the new standard of lagging on it
Its a big company doing it and they say they can fit the new heater with water heating to my old tank or fit a new one.i dont know what type of tank i have ? its electric !! What would you do...spend the £350or not ?
it would be a direct cylinder not an indirect cylinder if you were to install one. :eek:
APL he is on about adding a circulator on a warm air unit so it would be indirect cylinder not direct
I thought, but I might be wrong, that the add on circulator for the J&S warm air units was usually directly connected to a direct cylinder as APL is suggesting?
Tony
Proper way would be indirect otherwise the circulator would soon scale up
namsag,i have worked and changed hundreds off warm air units and cylinders and they have all been direct cylinders. :confused:
We had about a thousand on contract and everyone was indirect and janus 3 . You must live in a really soft water area.
Johnson starley say you can run up to around 15000 btu of rads off them and you would not do that on a direct system.
That is only something the guy looking at it can tell as he can see what condition its in
i do live in a soft water area,the ones i have fitted are janus 6 circulator connected to a direct cylinder i dont understand why you would run radiators when you have the warm air.
Because a lot of warm air units where not properly designed and a lot done just downstairs ,
People like the fast heat up of it and keep it and added rads for upstairs.
You say changed hundreds of cylinders on them why would that be not scale by chance.
