i dont understand why a water circulator would be used to run radiators it main function is to heat the cylinder you would be lucky to heat a couple of k2 rads when taking p/work and cylinder into account.15000btus would be no way near enough to do this.
What size k2`s 7500 btu ones .
Its simple its in johnson starley literature and its done and works . Same as it did on the maxol back boilers
Its for limited output 3 bedrooms 4000 btu`s a room hot water priority no one is saying its an ideal system but it suits some people. Who want heat right through the house but ducting was never installed.
I thought, but I might be wrong, that the add on circulator for the J&S warm air units was usually directly connected to a direct cylinder as APL is suggesting?
