Heaters are NOT reactive loads so should be OK.
I though that heatg elements usually used Nichrome or similar, which has an extremely small temperature coefficient of resistance? If so, whilst what you say is qualitatively true, in practice there would be very little difference in resistance (hence current) between hot and cold.The resistance when cold will be lower than when at operating temperature. Hence at switch on the load may be higher than the rated load until the heater reaches it's operating temperature.
Fair enough, but that's not really what I was talking about.There are self regulating heaters, the element(s) maintain themselves at a fixed temperature by varying the current through themselves. They can have a high ratio of hot to cold. That said they are not common in domestic use.
