WiFi Thermostat Install
I would say 217 volt too low to be a direct supply. AC has capacitive and inductive linking so a disconnected wire can show voltage with a high ohms per volt voltmeter, with the old AVO mark 8 I would measure using two ranges is voltage did not match then likely just due to linking not a positive connection.
Putting it simple guessing in no good.
So what not good? The wiring?
Unfortunately because of the 1st reading I wouldn’t take it for granted it’s a neutral wire. Might be time to trace it back. Sorry.
In the the boiler itself? The thermostat is in the living room, boiler in the kitchen.
