will a 10mm stop end work??
As previously, I'd stake my professional reputation on that Conet rad valve being 10mm, so the pipe will be 10mm.
Conet rad valves were discontinued many moons ago.
If you can make out what make the tee is you could get away with a blank capnut on the tee.
Bear in mind that not all 10mm compression joint threads are the same.
as i cant stop the thing weeping, i was just thinking about putting a 10mm compression stop end over the thread - biting on to the T
?? thanks for your help!!
i know that i need it to fit on the end of the valve...(were the red arrow shows)
Do you think this will be ok?
i need to make sure the od on the T is 10mm
ive fitted a 10mm stop end over it. and seems to be working a treat. thanks :) only a tiny bit bigger than the old drain plug! :)
