I have an existing outside cable run that feeds a power socket and light at the bottom of the garden.
I am getting rid of the socket and light but now need power in the shed I have recently built.
So....I dug down a small trench to find the old cable..carefully of course..and after isolating it.
It is twin and earth 19" down and in a 1.5 inch water tight plastic waste pipe. I have now extended the trench to reach the shed.
I intend to pull out the old cable and pull through the pipe some SWG I already have and then lay the SWG bare in the new 3m trench to the shed.
Then I will put some "Electrical Cable Under" warning tape 15cm above the bare swg and and fill in the trench. The cable is running under a patio and lawn.
The two ends of SWG I will leave for the electrician to wire up as required by regs.
I intend to photograph all this work to satisfy the electrician that the cable burying is sound.
1) Is the metod of burying the cable sound? The only issue I see is that unless I seal the end of the old exsisting pipe where the swg exits I guess water will eventually sit in he length of the pipe that the swg is in. Problem?
2) Will the electrician be happy with my photographic evidence?
I would leave the trench open and let the electrician inspect it all but I'm employing a sparky to do a much bigger job in later in the year and I cant leave the trench exposed for that long....plus the wife doesnt like the small mount Everest of earth in the back garden.
Cheers for any help/advice.
Rgds, Scott.
Rgds, Scott.
