After having a new UFH zone and LLH fitted to my CH system, I now have something that looks like this in the garage:
View media item 105686
I was thinking of insulating the pipes, however, I'm not sure exactly what the benefit will be. The garage has an excellent Hormann garage door, which actually gives a good seal where it meets the floor when closed, so I don't believe the garage could ever get below freezing, which might be the main reason for insulating the pipes.
Obviously, the other reason is to prevent heat loss, but from what I've read, I would need to use at least 30mm insulation for this to make a difference on 22mm pipes and there just isn't the space around some of the pipes for insulation this thick.
The third reason for insulating is aesthetics! I have seen some 6mm thick red and blue lagging which would potentially make the pipes looking more pleasing and help differentiate supply from return and hot and cold!
red lagging
blue lagging
I would appreciate your thoughts on the requirement to insulate the pipes.
red lagging
blue lagging
