- Joined
- 24 Sep 2005
- Messages
- 6,345
- Reaction score
- 269
- Country
Use the help... It is to the point... You could prevent a prog starting at boot by unticking, can also double click an entry to be taken to the relevant registry entry using regedit.. saves the hunting !This does not solve your problem but the tools (and others at the site) are very useful...
Did you look at the other stuff mentioned?
What about the first shot in the dark? Could this work in a similar manner when using the card reader as opposed to the floppy disk? Try the solution.. quick and easy to eliminate.
This was from my ref. 'Note the comments' Aaron Stebner's WebLog:-
I think Chris, above, is probably saying Jeff's method worked for him, it could work for you, try it... Mind you, he could just be offering a cynical reply.Friday, December 02, 2005 11:11 PM by Jeff in Spanaway
# re: How to resolve "Windows - no disk" errors when launching Media Center 2005 on an HP machine
I used this solution. Install the Norton Internet Security and Security Suite that comes with the HP Media Center computer, activate the products, use control panel to uninstall the Norton prosucts. This will end the No Disk Error. The key here is to install and activate then uninstall the products. I uninstalled the products individually then tried Media Center again with no errors.
Good luck.
Friday, December 09, 2005 8:10 PM by chris
Just so you know, It's not neccessary to have HP or media center in your equation! I uninstalled Norton from my self-built computer and am getting the error.... Thanks for solving this error mystery!
If nothing else you can slog through the microsoft.public.windowsxp.help_and_support posts I offered..
Once the experts are foxed for an answer there are few alternatives for the rest of us bar careful trial and error... with no burned bridges...
