Wintex Connection Could not be Established
As a rule a comport should be programmed as not used to connect a usb com and use wintex.
Unfortunately the com port adapter Texecom used to supply with the smart com no longer is and has to be purchased separately.
If you have a smart com connected then you don’t need to be using a usb com lead in the first place.
I think main issue is my internet is via a 4g modem and port forwarding isn't great.
It works on USB but not via SmartComm
smartcom shouldn't need port forwarding its a cloud based system. data wise it doesn't use a lot.
has wintex been setup for smartcom use, is the wintex version the latest as they periodically update the security certificates.
been on 8.2 build 0.0 for a while now, just download the Wintex file via the website and should get latest version
You was bang on the money secureiam.
I was on a texecom site but not the same as the one you linked to.
Downloaded the latest version and she connected right up.
