I have an odd-shaped garden and I want to install 2 LED security lights.
Light 1 has a PIR and is the main light. Light 2 does not have a PIR and should be activated by the PIR on light 1.
I have L,N, E and switched live (from the PIR) in light 1, and I believe that if I wired light 1 as per normal, then run a cable from the switched live, N, E to L, N, E on light 2, that it will do as I want.
However, there is no cable with the lights. Do I need special outdoor cable? I don't think the cable hole in light 1 is big enough for 2 cables so I am trying to find an alternative solution - any suggestions?
Thanks in advance.
Thanks in advance.
