As long as that socket is on the ring or radial circuit and not already a spur, then yes.Is it ok to connect 2.5mm wire to one of the existing power socket in the kitchen?
If you mean that you are fitting just one socket near the fan, then no, it does not have to be 4mm².or does it have to be 4mm wire. it will only feed single socket of 5amp current.
Provided the existing socket is part of a 32A ring final, or is on a 20A radial circuit, then extending it to one socket is perfectly fine, using 2.5mm² cable. (Winston has never read the regulations, thinks they are wrong anyway, and likes to make up his own rules.)
sorry for the confusion DetlefSchmitz is correct, that is what I meant; connect 2.5mm wire to an existing ring socket from one end and to a single socket to the other end. consequently; my fan extractor plug (5A) will be connected to the newly established single socketWell, actually he said he wanted to fit a single socket and draw 5A from it. Perhaps the OP can say if he meant a 5A type socke
Well, there are all sorts of regulations - as long as the fault current requirements are met.Have you read the regulations? Show me the reg that allows a 5 amp socket to be added to a ring which is what the OP said he wanted to do.
Ok, so why are they called that?A BS546 5a socket can certainly handle more than 5 amps.
By whom? Why should there be a limit of three?It was allowed to fit 3 of them to a 15a fuse
There you go.and I’ve seen one carry 15a with no problems.
No, not the equivalent - but you are allowed more than three on a 32A circuit (or 16A for that matter).Don’t think I’d like to put 39a through a 13a socket (fuse bypassed), but then as is often quoted “they don’t make ‘em like they used to”.
