Wireless Panic Button
Where u connecting to on the eurosec? U might have popped the 12v fuse
There doesn't seem to be any life to it when I connect the 12v There is nothing on the LED segment.
I have tried moving all the dip switches and still nothing. I would have expected some sign of life with the 12 v connected.
There is 12v on the input terminals on the UR2-WE so I don't think it is the fuse.
I can't see a fuse on the UR2
How have you confirmed 12v on ur2 ?
You could just use fly lead off battery on to ur2 .
Ok so I have made progress, I have got it so there is lights on. So a couple of red LED and Segment is showing 'U' then 't'.
Next step where do I connect the 2 NC Output A cables from the UR2 to on the alarm panel???. Bell or one of the PIR's??
Will need to be a seperate input as will need to be programmed as panic
ok all done and seems to work. Thank you all for your help. Now onto the dialler
Bell trigger to trigger dialler. +12v and 0v. Program phone number. Bobs your uncle
I have programmed it and loaded the numbers and the message. The last bit is the alarm to the dialler. I have the +12v and 0v, is it only one cable from the bell trigger to the dialler trigger?
Will only work for next few years. As analog telephone lines are going. Unless you are using gsm dialler.
