Indeed. We may see some of the glass based applications breaking out
On the topic subject an electrician said that I could use the wiring the thermostat currently uses and wire the receiver there.
I need to check with my electrical multimeter that there is a live, switched live and neutral wires for that.
I assume that there must be a switched live because the current wall thermostat, a Drayton Digistat 3, needs that.
Its a while since I used my multimeter so I'll have to mug up on how to do the testing of the wires.
The wires are:
Yellow connected to terminal 1
Red to terminal 3
Blue unconnected
Green unconnected (looks like an earth wire)
The mains AC at 240V for the current battery powered thermostat flows between terminals 1 (yellow wire) and 3 (red wire, switched)
The proposed SCR Receiver needs mains power so I intend to connect terminal 1 to N and 3 to L.
Would the team confirm that this is correct please?
The current thermostat is indeed battery powered. However when I put my multimeter across terminals 1 (yellow wire) and 3 (red wire) it showed AC 240V.
That's why I proposed connecting terminal 1 to N and 3 to L.
However I'm thinking that one of those terminals is the so called switched live so I may indeed have to test if the blue wire is neutral and only if so use it to connect to terminal N.
Also I don't currently know if the red or the yellow is the switched live.
And what does volt free contacts mean?
Confused more than ever.
Earlier on in this thread it was written that I should install it at the boiler's wiring centre.
I currently have an external Horstmann Centaur Plus C27 heating programmer wired to that centre fitted after the original Myson 700B electro-mechanical programmer on the boiler's front panel failed. The C27's installation wiring is here http://www.horstmann.co.uk/downloads/ElectronicDocuments/Central-Heating/C27-InstallerGuide.pdf.
So when I get the front panel off the C27 (the screw fixing it is currently problematic) I'll check how it is wired.
What you have to do is remove the Horstmann which is currently fitted at the wiring centre and replace with the new timer/programmer.
It may even fit on the same back-plate; it may not. I can't be bothered to look.
Then, at the boiler, you remove the two wires that run from the present thermostat and fit a short link between the terminals to which they were connected.
Remove or make safe the now REDUNDANT cable from the boiler to the hallway.
Repair hallway wall.
Sit down wherever you want and practice with the sender unit.
It (volt free contacts) means that they don't output anything of their own accord - they are just switch terminals - you can use them to switch LV or ELV.
Think of a lightswitch - that has volt free contacts.
Ah! to make and break a continuity in a wire? I assume that domestic light switches have a mains supply circa 240V whereas the switch between volt free contacts of the SFC will not handle 240V.
