How do you know what they would pay?
Go back to your OP. Basic system. Cheaper to get a new one. Especially for those in and around London.
To cover both visits?You can move the one you have for about a hundred quid - where are you going to get cheaper than that?
Agreed and accepted. No probs with an install,. The potential merry go round of remove/reinstall is the area of concern.Not to mention that a tenant isn't allowed to simply rip up floor boards for an alarm system.
The Police and Military where needed.
Ok James.....this is you isn't it......http://www.bondsecurity.co.uk/
So it is becoming quite clear to me that wireless is the way forward.
I've been fitting wired systems for over 25 years - but it's time to give the customer what they want. Simple installation, no carpets or floorboards to take up.
In the mass market of un-informed people who believe the salesperson's sale talk that may be the case.A wirefree system is the increasing way home alarms are being installed today.
Generally is not good enough when describing reliability and is dubious when talking about who is accepting wirefree systems.They are genererally very reliable and have fast become the generally accepted type of alarm installation.
That is not true for several makes of wirefree systems. You have been corrected on that before. A system using one way wireless communications cannot have self test, it can only detect when a sensor has failed to report for more than a certain time. It cannot test to see if a sensor is still actively monitoring. Two way commincations requires the sensor to have a receiver as well as a transmitter. The receiver will drain the battery. It is possible to have battery economy receivers. These turn on for a tenth of a second every second. If they receive a signal they remain on till they receive a message. The transmit has to transmit more than a second of pre-amble to keep recievers active before it can send a message. On certain radio frequencies that is not permitted. It also adds to the cost of every sensor.Modern wirefree alarms have extensive self test and fault indication.
Some modern piezo drivers can routinely test that the element is functional with a very short chirp during which time the element's capacity and resonant frequency are checked. If these have changed the device is suspect. Whether this function is used ion alarms I do not know.Bernard. A standard wired siren unit won't tell you the strobe isn't working or the piezo siren - only that the tamper switch is closed. It's not uncommon to have a silent siren up there.
Any good panel relying on relay contacts will detect a stuck contact and report it as a fault.Also, a common problem with PIRs is that the relay contacts freeze in the closed position. It may look as if it's doing something but is in reality a complete ornament.
