W
williamdjackson
Evening all,
New kitchen means new double oven and induction hob. I have the old style wylex consumer unit with one spare 32amp breaker which I think was used to supply a shower or immersion heater previously (shower now mains off combi boiler)
Can I use this to connect the new hob and oven? I think the wire is either 4mm or maybe 6mm and is currently being used for the security alarm!?! Was hoping to come off the ring main for the alarm and then run the wire from the old shower/immersion into the kitchen to supply the oven and hob.
Both the oven and hob are rated at 20amp each. If I use diversity this comes in at 24amp with the 5amp socket allowance.
Is 4mm wire ok or will it need to be 6mm?
Alternatively I could install a gas hob and just run the oven from this.
Many thanks.
Many thanks.
