I have recently purchased a 24,000 BTU Split AC unit. The supplier has advised that I need an isolated feed from the consumer unit fused at a rating of 20A, and this should connect direct to the external unit of the AC system.
I have a brand new house and don't really want to be chasing wires into walls etc etc as the consumer unit is at the front of the house and i need my AC unit at the rear (conservatory).
I have direct access to the supply before it enters the garage via this weatherbox (this is situated as the wire exits the house and before it heads underground): http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A340303&ts=54960&id=44658
Inside the weatherbox is a 30A terminal block with the obvious, live, neutral and earth.
My question is, can I take a live feed from this weatherbox, after 3m, drill into an exterior wall and bring the live indoors (conservatory), offer some sort of circuit protection to comply with the 20A requirement whilst indoors and then continue to the other side of the conservatory where the supply will then exit the house into the external AC unit. Im not sure this is the right method. Another would be to take a live feed direct from the garage which has one of these inside: http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A331827&ts=56032&id=63138
(well not the exact model but very similar).
Im sure there are several options but the right one is the one im after.
I am competent enough to carry out the basics myself, and will be calling in a professional to examine the work prior to connecting to the supply. I am also aware that this work is subject to notification
Thanks guys, i trust you to help me on this one as you've always done.
