Wiring a dimmer - SOLVED
20 Jun 2007
London
Hello all,
i hope you can help, I just want to check this is all ok as the instructions with my new dimer switch are not too clear
I am wanting to change from a normal light switch to a metalic single dimmer switch.
Just to check, would I
1 red wire into the dimmer at "L1"
1 red wire into the dimmer at "Wiggly line with arrow"
(therefore "L2" will be empty)
add a wire from the ground of the dimmer to the ground of the back plate in the wall?
Thanks in advance.
Old switch:
View media item 71557
New dimmer switch:
View media item 71558
thanks.
And I should add a grounding wire from the metal dimmer, to the metal back plate?
